Create the vendor class.
Define the custom option.
The switch follows inheritance and precedence rules for configured DHCP Server options. For more information, see DHCP Server.
Configure custom option data for the vendor class:
Switch:1>enable Switch:1#config t Switch:1(config)#ip dhcp-server vendor-class 20 custom-option-data 246 value 192.0.2.24 <cr>
The following table defines parameters for the ip dhcp-server vendor-class command.
Variable | Definition |
WORD<1-255> |
Specifies the vendor class ID. |
custom-option-data WORD<224-254> |
Specifies the DHCP code that identifies the custom option. |
value WORD<0-128> |
Specifies a data value to apply to this vendor class. |
